1 - 3 of 3 Posts
i recently rear ended someone in my 95 dakota minor damage to the front drivers side i pulled off the bumber grill fender headlamp assy hood and radiator i pulled out the radiator support and but on replacement parts from junk yards looks good but i go to start the damn thing and the radio all interior lights come on sounds good when you go to crank the engine nothing the starter does not even seem to be engaging ive checked relayes switches and fuses but it ran fine when i parked it to repair other than a leaky radiator im out of ideas you got any
All battery cables and wires hooked up including any extra ground wire to the radiator support?
Did you check all the fuses both under the hood and under the dash?
Loose wire/s on the starter?
Does the starter relay "click" when you turn the key to "start"?
95azdakota that is stumped
Did anyone answer your question concerning the damage to your Dakota - and it not starting? I have a similar problem with my 89 Dakota, which is
wrecked in the front. The two dealers I contacted don't have a clue.
1 - 3 of 3 Posts
