So I'm getting a DTC
P2127 - Throttle/Pedal Position Sensor Switch E circuit low
P2122 - Throttle/Pedal Position Sensor Switch D circuit low
It seems from 06 to 07 the V6 engine changed to remove the Throttle position sensor and looking at the gas pedal i'm not sure what the sensor in the assembly is. Also I don't see it identified as a part on line that I can purchase.
I just changed the EVAP and the PCM to clear a EVAP code issue so I'm wondering if I may have gotten a PCM for an earlier model or if I can just clear these two codes and they will not appear again.
