I tried to replace my front axel seal today on my d44,01, qc ,4x4 and i can't get the carrier out out of the diff. I everything is out, all the axels, bearing caps.
The parts store said it should just fall out with alittle prying,but it does not even move. I have read all the tech pages on the net and at pavementsuck.com and stil no go. I have broke all my pry bars and all out of ideas. Is there a tool or something for this??? Any ideas or advice will help.
Thanks, dodge dude
Ironram
there is a pry bar for pulling the the unit out i had the same trouble trying to pull mine are you trying to replace the driver side seal or the passenger side the passenger side you dont need to pull the unit just the cad housing and the first section of shaft but the driver side you do need to pull it good luck
Thanks for the reply Ironram,
Iam trying to replace both seals, Where do you get this pry bar and how does it look like??
Bushwacker!
