21 - 33 of 33 Posts
On an 06, the horn honk when you lock the truck key sequence works and as far as I can tell the seat belt ding disable works as well.
Thank you all so much.
Dodge Tech
ok boys today i had a change to hook the star scan two my ram and i wrote down everything that can be changed
1. Change Unit mesurment
2.Unlock drive door un first press.
3. Auto door unlock
4. Auto door lock
5. disable seatbelt minder chime
6. Enable cruse controle
7. FCM horn chirp duration
8. Illumanted entry time
9. Disable radio clock
10. Flash hazard lamps on lock
11. Headlight delay time
12. Restore vech Config
13. Add Navigation Radio
14. Change country code
15. Sound horn on lock
16. Program network config
17. Wcm Replaced
18. Program ignation key RKE
19. Erase all ignation keys
thats everything that was on the screen
Admin - David Mack
So after I added the RB1/NAV radio to my truck, I should get my dealership to flash the computer on the truck?
Dodge Tech
on a 06 you do since you gotta 2002 im not sure next tiem i get a 05 or lower ill look at the options with the drb3 the newer o6+ use a star scan are thay have a lil more options avable. and its not a flash its just enabling a option.
Admin - David Mack
Everything about the RB1 works OK. I use the NAV system from time to time and it's great but I can't find how to change the time on the clock. And NO, I do not want to hijack the thread for the stupid clock. I'll find the information on a different thread or start a new one.
Dodge Tech
to set that it would be in the owners man thay display all the radios if not pm me and ill pull up the procedure on dealerconnect
3. Auto door unlock
4. Auto door lock
17. Wcm Replaced
sweet, thx bro
Bright silver & chrome!
Dodgepu360 said:
what does the (HSA) Hill Start Assist do?
What he said...
The HSA prevents the vehical from rolling back when going from the brake pedal to the throttle pedal on hills.
Quote= " Maintains the same level of brake presure the driver applied for a short period of time after the foot has been removed from the brake pedal. The system will release the brake pedal in proportion to the amount of throttle applied. If the throttle is not applied within a short period of time after the foot has been removed from the brake pedal, HSA will release brake preasure."
That explains why my 07 will not "idle" up small hills when I let off the brake.
21 - 33 of 33 Posts
