i have a 2007 ram 1500,when i press the cruse control button on,sometimes the cruse light come's on but no set,then light will go off,sometimes i press cruse button the light will come on then goes out,sometimes i press the cruse button and light will not come on at all,can someone please help,thank you
If you don't have any kind of speed sensor codes then it may be as simple as the button itself. Recommend testing it before you just start throwing parts at it.
thanks for reply HemiLonestar,i dont have a engine light,dont have no codes or atlease not on my hand set,i just have a basic hand set to check and erace codes and remove engine light ,do i need to remove switch to test or check it,or can i check it in the truck with a hand set.or if it is another issue,what can it be,thanks...
First guess is you have a bad wheel speed sensor on the front, if it was the rear, the speedometer would be jacked up.
Related Threads
DodgeTalk Forum
4.7M posts
290.1K members
Since 2002
