1 - 7 of 7 Posts
My CC doesn't work anymore, nothing happens when i hit the button, no light, no CC? Any ideas where to start 1st? I check, there is no fuse for it? Is this something the dealer has to fix? I would let it go but i have a few roadtrips coming up soon.
have your wheel speed sensor checked... it runs your cc,abs,and 4wd, its in your wheel bearing.....mine started to go and i lost my cc to.
Sounds crazy, but are you having problems with your battery holding a charge? My break light switch went out and it was causing the ECU to think I had my foot on the break and then the cruise wouldn't work. Changed the switch and the cruise worked. My tip was the battery going down, and I finally caught the break lights staying on. Problem solved.
is that the only thing wrong? abs light or anything on?
Tricked out Ram
It is also controlled by the FCM
Discussion Starter #6
Problem fixed, I had the wheel bearing replaced. I guess the sensor was part of the bearing and it was bad. Thanks for the suggestions. You guys rule!
msmith987
were there any other indicators as to it being the speed sensor? is there a way to test this? I have been w/o cruise for years...no abs light or anything like that...just no cruise control.
1 - 7 of 7 Posts
