1 - 2 of 2 Posts
Dodge Ram 1500 2004 3.7
Just installed new /used motor in my dodge ram 1500 2004 3.7 , it would not start up found out it was due to motor being specific on the year ,the cam shaft tone ring was wrong so I changed timing chain set put correct one on it started up on first try,but after I turned it off it would not start back up obd2read crankshaft sensor witch confused me cause before I did timing I had just put a new one in so ok maybe it was defective I thought went to stare exchanged for new one put it in then it stArted rite up again but I noticed it wasn’t getting any oil pressure so I replaced the oil pickup stick,oil pump ,oil pan ,set timing again,put everything back together put new crankshaft sensor in again it started just fine oil pressure read perfect shut it down but it still telling me the crankshaft sensor is bad can any one help this has turned into z night mare for me all I want is the truck to start up good and run the way it was made to run please if you gave any suggestions I’m all ears
1 - 2 of 2 Posts
