I bought this cam from a friend that is a lead mech for dodge a few years back for $100 and wanted to know if it would be worth the time installing he said its a mild cam
Its a Crane Cam Powermax 2030 Part # 704121
lift- intake @ cam 286 @ valve 458
exhause @ cam 292 @ valve 467
Min RPM 1200
Max RPM 5200
valve float 5800
States it improves Lo and Mid-range Torque and Hp
i do not know a lot about cams would would like an opinion Its used is that ok? I was planning on installing it with new lifters and with the Edelbrock Heads or the R/T head and also with some rollerrockers
Im also thinking about stroking the 360 to a 408 - 426 would i need a bigger cam
Min RPM 1200
Max RPM 5200
valve float 5800
