1 - 2 of 2 Posts
different fuel rails.
rams have one port for a quick fuel disconnect. you need to find rails with two ports.
I do know other dodge magnum engines have complete return systems. the ram model pump just spouts into the tank extra fuel right out the top of the pump. the regulator is in the tank with the pump. and there are ways to retro to a full return system, I've seen kits for sale with an exterior pressure regulator, but- the current stock system should SUPPORT 500 HORSES.
look into http://stores.hi-potek.com/fuel-rail-fittings-hose-plug-n-play-kit-blue-red-or-black-for-hipotek-6an-fuel-rails-3-9-5-2-5-9-dodge-magnum/
try to contact him about the subject.
or look into a Durango or Dakota fuel system.
or
http://www.southeastrt.net/index.php?main_page=index&cPath=248
ask him
or
https://www.performanceinjectionequipment.com/
ask him
return systems are easier with billit fuel rails. normally return systems are used with forced induction systems.
or
http://www.hughesengines.com/Index/index.php
1 - 2 of 2 Posts
