Serving temps were nearly the same. T-stat housing hose temp was 167. With the cardboard it went up to 169. Blend door was completely closed. To the full heat position.
With 195 stat, should read 195 ish (unless IR gun or reading is off).
... My 99 has 195 stat; my MiniTemp by Raytek gun reads 190+ just above clamp/stat (but it's a pain to get good readings on the buried Magnum hose).
... Have a small suspicion the Stant Superstat type stats are not helping, totally unsure though (no proof at all; and not gonna waste an nickel or minute to find out).
Air blows warm at normal idle now, but blows hotter with raised RPM's. Possible causes?
Has some htr core restriction (as said before, seems
unless core is perfect/new there will be poor heater output at low RPM; your not alone, seems it's the bane of Magnum V8 owners that need decent heaters for colder climes). ... As ambients drop, your problem will worsen (depends what your willing to live with).
.. Helpful to mention your
normal winter, and coldest winter ambients.
... When mode control is set to any "non recirculation" position, pretty darn sure yours
will blow colder at higher/highest fan speeds (
unless RPMs are high!).
... Earlier "bypass delete" link mentions the proposed "
3/8" ish ID bushing/restricter mod"; spun360 installed a 1/4" ID bushing later in thread; you'll notice I'm a firm proponent
the Magnums huge total bypass volume and chintzy water pump are the biggest cause of this all to common problem.
