1 - 6 of 6 Posts
Washing the underside of the truck i could swear i saw yellow/greenish fluid from the rear half of the truck... Not a lot - but noticable.
Is there a seperate reservoir for the rear heater? The fluid level is good under the hood...
Where can i get asystem description and system diagram for the rear climate system?
-Thanks!
You have coolant lines running on the passenger side of the truck too behind the rear tire. Check and see if you any leaks running on the rear cooling system. This once happened to me but I was not able to find anything.
Are your sure it is green? I just drain and filled mine, and it is the Dexcool(Red/Orange).
Good info (both)
Thanks!
I will check and report back...
Good INTEL! Thanks!
1 - 6 of 6 Posts
