Hi fellas,
I just got a '96 1500 4x4 (RED!). I bought it knowing the heat didn't work very well on it. Well, here's the problem:
When it's really cold out (say below 30 degrees (NOT 30 below 0)) the heat is almost non-functional. The guy I bought it off of said that he had flushed the core, replaced the t-stat and water pump already. Here's more detail on the symptoms.
If I leave the heat on low or medium it's nice and warm today (when it's +30 degrees, right now it's like 43 and it's pretty warm when I leave it on the floor on a medium fan speed). Whenever i put it on defrost it stays kinda cool, especially if I have it on high, then I might as well turn it off because there's no way it's defrosting anything. The thermostat seems to function correctly as I can see the temp gauge move when it opens. The guy said that he thought it was a problem with the HVAC unit. The blend door seems to move just fine because it will go from the "warm" that it does produce to cold and back just fine and I can hear it moving. Also the interior / exterior air door works fine too (I can see it through the glove box) but there are no changes in actual temperature by changing the settings to interior.
My opinion: Heater core because it operates better with lower fan speeds which kind of tells me that it's not getting GREAT flow but it's getting some.
Ideas anyone? Perhaps the blend door is moving over but not all the way?
