1 - 2 of 2 Posts
About a month ago I put a new aftermarket pair of taillights on my car, put on an alarm and put in some subs. Shortly after that I kept blowing fuses on my taillights. The brake lights work fine but when I turn my lights on at night and drive the running red lights go out but my brake lights still work. I put my stock taillights back on and it is still doing this. I took it to the dealership and they said that they couldnt find anything wrong with it. They said it could be the alram or the subs. Has anyone had this problem? Does anyone know the solution?
Probably have the parking light flash from the alarm system hooked up wrong. The brake lights are on a separate circuit, which is why they keep working, but the alarm wires into the parking lights to flash them. On most cars this signal drops to ground to turn on the parking lights, if theres a problem with the alarm or the Magnum doesn't work that way you could be shorting out the system. I'd look at that circuit first.
1 - 2 of 2 Posts
