I have a 99 Diesel 3500 with the infamous "53" block. Needless to say we had to replace it recently. We bought a '00 engine, put it in yesterday, however the ecu is bad.
Are their any good used parts/junkyard websites that I could find one at?
Also, what years could I pick from? Right now we have it running with the 99 computer from the old motor. However it doesn't run like it should. I've found a couple 01 ecu's, but wasn't sure if they changed at all from '00 to '01.
Discussion Starter #4
Just called our Dodge Dealership, and they said they wouldn't be able to reflash it, being that the part numbers are different.
However we just found a ecu from the same year motor, with the same part number, so we should be ok. (I'm assuming that one may need to be re-flashed?)
