I would say that is incorrect. try looking behind the battery cavity near the headlight bucket. It should be right behind there with a plastic tube that allows air into the SBEC,(Single Board Engine Controller or it's now refferred to as the PCM,(PowerTrainControl Module), the tubing allowed cool air into the 'PCM's" motherboards and relays, this cools the unit, Chrysler later placed all the relays on the outside of the PCM. To test the SBEC you need to find the OBD-I connector near the hood hinge on the drivers side, it's a 6 pin connector, plugs into any generic scan tool provided you have the 6 pin connection adaptor for Chrysler, most OBD-I scan tools have assorted adaptors to hook into the 6 pin connector. But you can retrieve most of the codes from the key On/Engine off test. A piece of paper and pencil is handy, it will start with code 12 and end in 55,( one flash then pause, then 2 flashes)(5 flashes pause then 5 more flashes), this is normal, try to get the codes between these 2!! Good Luck
