1 - 2 of 2 Posts
2wd Dak, 4X4 soon
I changed my plugs and wires recently but the conection between the coil and wire is bad and doesn't seem to fit right. If I push it on it runs good but then after a few miles it starts missing again so I push it back on.
Should I just crimp the connector a bit to tighten it up?
which wire are you having trouble with on the coil the plug/coil wire? or the connection wire at the bottom, sometimes when that connection wire gets hot it can cause it to misfire i had to unplug it..kind of a reset, i just ended up buying a coil so far so good, no missfire
1 - 2 of 2 Posts
