1 - 16 of 16 Posts
\m/(-_-)\m/
I need to wire the sensor ground on my wideband to the common ground as the coil. Any info would be nice!
\m/(-_-)\m/
I need it grounded to a common ground for the coil for minimal interference.
Toothy Critters Rock!
My wideband just ground off the power outlet or cig lighter ground. coil ground is just the normal ground not the supposedly "cleaner" ground that all the low voltage sensors use.
The body point where all the grounds come together should be a very clean connection point.
Got 2 Hemis
A ground is a ground. As long as there's no paint under your connector, where you ground it doesn't matter (shorter is better, though).
Tricked out Ram
ALL related grounds should be soldered together and put in one place as a common ground if possible.
\m/(-_-)\m/
Discussion Starter #7
Well the Sensor Ground, Heater Ground, and Shielding ground will all be going to the ground. I think I will try a ground near the foot petals, or hell I may just try grounding it at the cigarette lighter. I currenty do not have the Sensor Ground or the Shielding around my twisted pair grounded. The Sensor Ground is labeled Boost Ground but I feel pretty confident that it is the Common ground for all the wideband sensors, which may be my problem. I had to look at other wideband and datalogger installation instructions to figure this out, they all have a sensor or digital ground.
My fingers are cross that is will fix the strange spikes in my RPM readings at WOT!
Oh that's right you have the data logger and wideband together.
I think the cleaner sensor ground would be the one on the passenger fender by the PCM, think that is where all the pcm grounds connect.
\m/(-_-)\m/
Discussion Starter #10
Damn it!
But I can flip people off and get away with it! hahaha
:thatfunny
he's probably got a couple he can cross on the other hand
\m/(-_-)\m/
Discussion Starter #12
Cool, I am sure hopping this fixes my problem. It has been a royal pain in the ass! I have redone this damn think so many times lol
\m/(-_-)\m/
Discussion Starter #13
Well there is worse things you could slam a door on.
\m/(-_-)\m/
Discussion Starter #15
God forbid!
1 - 16 of 16 Posts
