1 - 6 of 6 Posts
hi new to this forum, need help with my intrepid today i was driving and all of a sudden it started missing, then the check engine light came on. when i got home i checked for any codes and got P-1684 and P-1391. thaks for any info
2.7 Trauma Surgeon
p-1684 indicates the battery was disconnected in the last 50 ignition cycles and dose not mean there is a problem-- p-1391, however means loss of ckp or cmp signal-- so sounds like you may need a new crankshaft sensor or camshaft sensor--
2.7 Trauma Surgeon
crankshaft sensor is around $70 for the old style, and $15 for the new style i believe--
2.7 Trauma Surgeon
if you have the chrysler new car warranty 3yr 36k, that will most definately cover it--if you have extended coverage or an aftermarket warranty, then you would have to contact the warranty company or dealership and ask-- they have many different coverages--
1 - 6 of 6 Posts
