1 - 3 of 3 Posts
I had to replace my catalytic. New O2 installed as well. Im getting the following codes P1128 P0135 p0133 p2096
Also my drivers side headlight is not working low or high beam, bulb not burnt out. Any ideas?
Based on those codes you have a problem with the bank 1 O2 sensor circuits. Check your wiring, and check your plugs. You could have a broken or damaged wire, or a bent pin or pushed out pin in the plug. These codes probably all relate to a single problem. Also check your fuses for the O2 heater circuit.
1 - 3 of 3 Posts
