1 - 7 of 7 Posts
Coming home tonight my check engine light came on, I check and it has a code P0442 Evaporative Emission Control System Leak Detected (small leak).Where do I start looking for this problem? Any help would be appreciated! :help:
Nevermind.
tighten your gas cap . diconnect your battery for a few minutes and hook it back up to clear the code . evap code, your gas cap was lose more than likely. sounds stupid but trust me.
The dealer told me to hear 3 clicks. Then you are good. The light might also not go off right away....but wait and it will.
2006 Magnum RT
i had same thing
had to replace my whole gas tank. I have a vibration now when you first stop and if you turn the wheel 1/4 of a turn brought it back 7 times they have no clue. They said it was a sensor that revs your truck at low speeds already changed it once it lasted one hour. They also said they would give me a new truck now I cant get them to answer the phone. :help:
thats correct your system detected a leak in the emissions system, if it was the gas cap it should clear itself your truck has a leak detection pump on it and the computer monitors it but sometimes it takes a couple good "trips" for it too clear and the computer see's a trip as more than just turning the truck on, if the light stays on after a week or so then you have a split vacume line somewere, no big deal but the light will stay on till its fixed.
dont disconnect your battery it wont help or turn the light out just let it run its corse like i said. If it is the gas cap it will clear almost right away
1 - 7 of 7 Posts
