I just installed new master and slave units... by the book, I cut the plastic tabs off the slave after everything was installed and now i have no pressure in the clutch pedal. I believe the problem is in the aluminum/connector that plugs into the slave unit, not sure but it seems to be connected good, not really sure how fluid gets past that point. do i need to bleed the system at all?
