1 - 2 of 2 Posts
I have just bought a 93 v6 4x4 and the clutch would only just release right at the floor and was really stiff.
I removed the slave cylinder to see if there was anything adjustable or loose, when I came to refit it I was a bit concerned about how to line up the rod with the clutch release arm as there is nothing to keep it centred while you refit the cylinder.
Has anyone got any advice on this (both the fitting and if the clutch is likely to be on the way out)
Thanks
mozzer
· Troubleshooter
depending on the mileage and more importantly, how it was driven it's very possible the clutch is on it's way out, as for the fitting, I wouldn't know where to start, my experience doesn't extend to standard trans
1 - 2 of 2 Posts
