I just reset the clock on the D for the time change, and realized mine won't let me adjust the minutes. I can adjust the hour as normal. The radio is the RAQ. Any ideas?? Thanks in advance.
I thought after you adjusted the hour, you would press in the right knob. Maybe I shold look at the manual one more time. Thanksumm snap.. I'll have to do that too, I beleive you have to tap a button and it moves you over to the minutes.. I just can't remember which button...
Push the "Time" button until the hours blick, then turn the right button, "Tuner/Audio", to adjust the hours. Push it again to adjust the minutes. Then either push it yet one time or just let it time out to get it back to normal operation.
I changed from CD mode to radio mode to set my clock, maybe that is what it takes to work? I have no idea why I did it and it doesn't say anything in the manual about setting it radio mode.:huh:I did it just like that, hold the time button down, use the tune knob to adjust the hours, than press the tune knob again to adjust the minutes and it just times out.
I've always done mine with the radio off. It's worked like that before. I'll try your way. Thanks....I changed from CD mode to radio mode to set my clock, maybe that is what it takes to work? I have no idea why I did it and it doesn't say anything in the manual about setting it radio mode.:huh:
On mine, the minutes aren't flashing. So, that means it won't let me set the minute.I ,hold the "time" button until it flashes, then set hour, push the button again until minute flashes, adjust minutes, then ignore until reset.
