1 - 3 of 3 Posts
I am taking it in soon, but thought I would get a few opinions....
When stopping (from 10-15 mph) I get this clink noise, just once, like a something is loose. A bit of investigation I think it is comng from the transfer case as there seems to be a bit of play when rotating the drive shaft. If it is that what can I expect in terms of cost. If not, thoughts?
4x4, Straight pipe roar!
I had clicking like that and it turned out to be my front axle u joints. Wiggle the axle where the ujoints are and if you can almost mimmick the sound then thats your problem.
same happened to me. it will only get worse. i let mine go and it was clicking constantly. finally repaired it.
1 - 3 of 3 Posts
