Well last weekend I was driving around and all the sudden the light comes on. I drove it for a day then brought it to Autozone to get checked. They said the O2 Sensor in Bay 1 was slow in responding. The guy said it was the first one on the passenger side of the engine. I have not replaced it yet, and have been driving the truck around. The light suddenly went off on Monday. I am still getting crappy gas mileage though. Anyone know anything? Also what is the difference between the OBD reader at Autozone and the one the dealerships use. Because dealers are charging $80 to find out what is wrong and Autozone doesn't charge me anything. Also my brothers Jeep Grand Cherokee's light just came on yesterday so I am going to bring that up to Autozone today. Thanks for all the help.
I little trick is to turn your key on 3 times in a row.them your odomiter will flash a number or it will say done if there are no coads. If you need more help let me know and Ill give you detter instructions (its a trick us poormen use insted of a $300 scan tool)
Well I ran up to Autozone today and they hooked it up to the OBD reader and it came up with a small fuel leak. The guy said to make sure the gas cap was tight. So I took the cap off and put it back on and he erased the code. I think that was what was wrong with it because I drove it back home (15miles) and no light came on. If this wasn't the problem would the light come back on.
you know that happend to me the engine light but it goes off and on like its a short in my wire. but now it hasn't turned off, so I don't know but it drives great.
The OBDII scan tool Autozone uses works fine. I bought the same unit and have used it successfully on a couple of rigs including my Ram. About the oxygen sensor code -- there are two sensors, one before and one after the cat. If the front sensor must be changed, know that the aftermarket unit (Bosch, others) may not have a long enough pigtail to reach the truck harness connector. A replacement from your local Dodge dealer fits and is actually cheaper. ;)
