1 - 9 of 9 Posts
Spending
Put in a new intake, slipped the sensor into the intake (all the way), only problem im having is, i cant get the "check engine" light to go out... i tried sticking the sensor all the way into the intake but nothing prevailed. any options?
did you try just disconnecting the battery overnight?
Or for about 30 seconds, which ever is quicker...lol
Disconnect the negative cable and turn the key to ON for 30 seconds.
Spending
Discussion Starter #5
thank you
Hey Neil, I wonder who started the "key on for 30 seconds" thing originally? I've cleared three codes with the neg cable alone, so I wonder if this is an urban myth...
I don't think it's a myth.
1. Ask on the DOC, that's I first heard of it. Fastman also told me the same.
2. If a problem has really been corrected, the lamp should go out as right away.
on older pcm equipped vehicles most times you could get away with disconnecting the - for ten seconds or so to clear the light. now , in most cases that won't work.
two ways that i clear codes when scan tool isn't available are:
disconnect - and turn key to run for 30-60 seconds OR disconnect both + and - touch them together and hold them together for 30-600 seconds.
both methods discharge the capacitors in the pcm, basically killing the keep alive memory. both methods also kill any adaptive strategy learned. fuel trims, pulse widths and others are reset to base values and must be relearned by driving. SOMETIMES resetting adaptives is not a good thing.
i prefer using a scan tool to reset but sometimes not handy.
to correct neil f, MOST codes will NOT reset themselves until a number of key cycles or warm up cycles or readiness test passes have completed. some(open or shorted) types will reset and turn out the light but there will still be history codes that can be accessed with scan tool.
Pimp On Sir Don
So did the code go away or what?
1 - 9 of 9 Posts
