1 - 7 of 7 Posts
Hi I'm new to the boards and i was wondering if anyong had expiriance the EVAP and could help me.
Says I have a small leak in my EVAP
Checked Gas Cap It was tight. What else can I check?
Valdez Racing Team
...you might want to test with a different cap (I know you said it was tight), I thought mine was tight too, went ahead an bought the mopar locking gas cap, reset the pcm, the light went away...
Great Idea, I think someone was jacking my gas about a month ago. A locking gas cap would be a good idea.
Will my computer reset itself or will I have to do it manually?
Valdez Racing Team
You have to do it your self. I do it the old fashion way... I remove the Pos (+) cable from the battery, insert the key and go thru the start motion (this will discharge any lingering power in the system), re-attach the battery cable and call it good... the check engine lite should not appear.
God forbid a gnat's fart worth of gas fumes might escape into the atmosphere. If the gas cap ain't it, there's a hose that goes from the gas tank to the canister next to the gas tank. It tends to dry out over time and can leak a teensy bit.
I just started getting 00422 (I think that's what it was).. medium evap leak.. I'll try the gas cap too..
1 - 7 of 7 Posts
