73 W100 360. no upgrades to the charging system (yet)
Im starting to work on some upgrades to this truck. I started with replacing the instrument cluster VR. as seen here:
http://www.allpar.com/history/mopar/electrical2.html
I was testing the output with a multimeter. i found that the input had 17v. the 5v output was not working. this is another story.
While the engine is running the battery is showing 17v. Sooo that is high. I tested the VR. (see pic) Im gettging 17v on the red wire and 7.8v on the yellow.
What is happening? Why is the charging voltage soo high? I dont understand the readings on the regulator. I tested it on 2 different grounds.
