I want a Blown Hemi
I have a 2008 sport and I do the oil change and service every 2500 miles. I dont have the dealer do it but a local shop and at 5000 miles my change oil notification went off. Is there anyway to reset it or turn it off after each oil change.
turn your key to run position, mash your gas peddal to the floor three times and start your truck. make sure you dont have a floor mat or anything that will prevent your peddal from reaching 100%. the key cycle and gas peddal sequence must be performed in under 10 seconds
I want a Blown Hemi
Thanks
Thanks for that tip! I just did it and well see tomorrow morning if it worked. How do you figure out all the little codes and what to do for little problems like that? Is there a hemi quick fix book?
I hit the pedal to the floor three times with the key on then turn it off.
