2004 3500 CTD
Just did some looking around and talking to several guys that have installed the Bully Dog outlook monitor in Fords, Dodges, etc. The epoxy glue that is supplied in the kit will cause the inner pane of the window to CRACK!
The company I purchased mine from called his supplier and his supplier said BS. But when he went out and looked at his he called right back and had to eat some crow. His was cracked also.
At this time it sounds like their may be something going on with the epoxy heating and cooling causing just the inner pane to crack. We seen one that took off and ran up the window. The others are staying just under the mount.
Any others seeing this same issue? Sounds like Bully Dogs supplier for the glue will be working very fast on a solution. In the mean time you might hold off on using their epoxy adhesive to mount the outlook monitor to your windshield.
Thunder
C HEMI GO
What's an outlook monitor?
5 Years... 6 Dodges
Jeep Driver
This needs to be in the Diesel section, so it makes sense to those who read it. :)
