I have had a flat spot in my carb ever since I rebuilt it several months ago. I am getting tired of it. I was pretty certain it is related to the accelerator pump as the hesitation occurs accelerating from a stop or while moving slow abd speeding up.
I Finally pulled the cover off the air cleaner and the accelerator squirt appears to exist as soon as I move the throttle, but it is very small and sort of "dribbles". (this was done with the motor off if that matters). Is this a weak pump spring issue or should I be thinking along different lines. It just does not want to seem to squirt much on its own.
After I rebuilt the 383 last month, I decided I want to go with a 4 bbl. This likely will be a spring project, so I have a few questions while I collect parts. I have an old 4bbl manifold from a 383 but was not certain if I need different throttle and kick down linkages. Are the 2 and 4 bbl factory linkages different? Finally, I was initially considering a 670 Holley truck avenger, but can track down a era correct thermoquad for much cheaper. I want vacume secondaries, and am not sure if the thermoquads are of that design. Finally, of the two, what are the pros and cons? Is one better than the other?
Thank you for any assistance/advice you offer.
