1 - 2 of 2 Posts
I am looking for the Wiring Diagram for the Radio in a 2005 Dodge Magnum R/T, With the Six Disc CD.:rck:
Exact wiring situation varies depending on if you have Nav or steering wheel controls, these are the basics:
- Connect the Black wire to the ground wire.
• Connect the Yellow wire to the battery wire.
• Connect the Red wire to the accessory wire.
Note: If installing an ASWC-1 (sold separately), there will be an
accessory wire there to connect as well.
• If the aftermarket radio has an illumination wire, connect the Orange wire to it.
• If the vehicle is equipped with a factory amplifier, connect the Blue/
White wire to the amp turn on wire. This wire must be connected to
hear sound from the factory amplifier.
• Connect the Blue wire to the power antenna wire.
• Connect the Gray wire to the right front positive speaker output.
• Connect the Gray/Black wire to the right front negative speaker output.
• Connect the White wire to the left front positive speaker output.
• Connect the White/Black wire to the left front negative speaker output.
• Connect the Green wire to the left rear positive speaker output.
• Connect the Green/Black wire to the left rear negative speaker output.
• Connect the Purple wire to the right rear positive speaker output.
• Connect the Purple/Black wire to the right rear negative speaker output.
1 - 2 of 2 Posts
