1 - 2 of 2 Posts
Has anyone replaced the camshaft oil seal? Is it easy? Do you have to remove the timing belt or can you just remove the sprocket and have someone else hold the belt under tension while you remove and replace the seal? My van has a 2.5l turbo 4. :help:
Do It In A Van
I think you can get the seal on by just removing the camshaft sprocket.
Use some tie-wraps (zip-ties) to hold the belt to the pulley. Be sure and keep tension on the belt or it may slip off the crankshaft gear and then you'll have to tear the whole thing down and reset the belt.
1 - 2 of 2 Posts
