1 - 18 of 18 Posts
mafosa
does anyone know the krc 270 cam (non mds) is compatable with the manely package. ie.. (springs, p-rods and retainers..) thanks inadvance..
Inertia ROCKS!!!!
Krc 270?
mafosa
210 typo sorry
Inertia ROCKS!!!!
I think the Manley package is a recommended valve train upgrade for any cam swap.
mafosa
thats what i thought. im trying to keep all the geomitry correct.. so for every day driver plus towing the krc 210 cam and the manely package is the way to go then.. anyone what to chime in?
mafosa
i was told that cam required a arc-1 piggy back. the krc 210 is improvment from that comp. what do you guys think??
Inertia ROCKS!!!!
The 260 and 210 are practically the same, and I don't think either of them requires the ARC-1, but I bet you would get the most from the cam using it.
All Around Great Guy
268 or bust!
Where do you get these ARC-1 units?
mafosa
Discussion Starter · #12 ·
if you go with arc-1 do i loose my superchip software?
Had 392.. Now.. LS2 GTO!!
nope, you get to keep it. i am doing 210 its better for day to day driving and more tq than the 218 krc cam from 1800-3500.(my truck is my daily driver and the MPG won't suffer from just the 210 anything bigger will because the need for more fuel air mix) i will let you all know how its goes i just need to install a buddies converter first.
Inertia ROCKS!!!!
HEMI450HP said:
I agree...I dont think the KRC 210 or the Comp 260 are agreesive enough to justify the increased cost of just doing a 6.1 cam swap. I would either go 6.1 for about $150, or go with the 268 or bigger with the Arc-1 for about $550.
You're should also get a wideband O2 sensor to monitor the air/fuel mixture when you step up to the 268. I don't see how you can adjust the ARC-1 without knowing if you're lean or rich. That will add another $350-400.....
Inertia ROCKS!!!!
Also some sort of upgrade springs with a cam swap....
Inertia ROCKS!!!!
Would i be happy with a 105 dollar 6.1 cam? Or would i just get pissed at the performance and wish i spent 300 more for a better cam and tune it?
1 - 18 of 18 Posts
