1 - 20 of 40 Posts
Looking to paint my calipers this weekend. Any suggestions on what color you think would look the best. The color of my truck is patriot blue. I was also looking at the Dupli-color kit because it sounded like the easiest to apply. Thanks for the help guys.
Member
Red is the best color for calipers IMO. Duplicolor makes a great kit. That is the one I used. Prep is the key to making them look good. The better you prep the better they will look. Thye make a blue color or even the yellow might look OK with the Blue. But IMO calipers should always be Red. Good luck, and post some pics when you are done. Here is what mine look like.
Red looks good on any thing. Go with that.
Jeff, did you take your calipers completely off and reinstall them after you painted them? Or were you able to leave them connected to the brake line and paint them?
Inertia ROCKS!!!!
What's this kit you speak of? Does it come with some sort of special paint, maybe something that would withstand heat?
Duplicolor has a kit for $15 bucks at Advance auto/Autozone.Comes with caliper cleaner,caliper paint and a brush to apply it.
Inertia ROCKS!!!!
Cool thanks, how long does it take to dry before you can reassemble the brakes?
Hemi2nV
When I get around to installing my powerslots and ceramic pads this winter I plan on painting my calipers gloss black...Im going with the duplicolor kit
I never took mine off...if you're careful a great job can be done leaving them on. I was off and driving in about 30 mins after painting them.
Member
I took off the rotors and pads to do mine. You do not have to do that to paint them, I just felt like that was easier. I hate taping things off. I get to antsy and never do a good job of it.
I also suggest using the kit or at least the engine spray paint. It is designed to be able to take larger amounts of heat. The regular automotive paint would crack and peel.
Can't wait to see all of those RED painted calipers!!
I vote Red.. Goes with everything.. :)
United States Navy
The Blue kit from Duplicolor is very nice, contrasts nicely with the Atlantic blue but would look equally as good with the Darker Patriot blue I would imagine. Also, if you dont have them already, get the rear wheel well liner from Dodge. Really, cleans up the rear tire area.
Is one kit enough to do all 4 calipers? I was planning to do it this weekend.
yea i did 2 coats on all my calipers and had enough paint left to do like another 5 coats! and i really didnt wanna tape anything off either so i just didnt. if your real steady with your brush you'll be alright. just make sure its real well lighted cuz it gets dark under there.
6.1 FTW
Used about 4 coats on each caliper. Still had 80% of the paint left! I found that it looked real spotty until at least 3 coats were on, but looks great when finished. Has stood up pretty well to after being on about 10 months now.
I just used Rustoleum Sunrise Red oil based paint from Home Depot. Got a bunch left in the can. Did my truck and my Brothers Tahoe. Only took 2 coats each and its thick and lustrous. I think mine has been on there close to 2 years and is still glossy and bright.
Just cleaned with brake cleaner, scrubbed everything down, covered what I didnt want painted with aluminum foil and paper. Then brushed it on with small foam paint brushes. Cheap, easy and awesome. havent done any maintenance ont hema side from wipe them down with some windex on a cloth when I wash the truck. I also give them a really good cleaning with windex and a cloth when I rotate my tires.
KB
Red looks sweet.
1 - 20 of 40 Posts
