I saw a need for a spare jack-I couldn't count on the factory jack as my only tool to get my truck up in the air. I wanted something light with a good lifting capacity. This was the best solution I could find. 8000 lb. and 30" lift capacity. Weight is 19 lb. I tried it out today, and here is my review. I had to cut the end of my exhaust pipe square to get a good seal. You need to physically hold the hose on the end of the exhaust pipe due to back pressure. The hose is like fire hose and you need to keep it un-kinked. I tried to find the center of gravity to lift both l/s tires off. In the picture the rear tire is well off the ground. The front tire is able to spin by hand. IMO this is a good jack for stock height Power Wagons. It will really be good on soft ground. It comes in a great compact storage case, and would have more lift options than a Hi-Lift jack. It also has a standard air fitting if desired. The exhaust would fill it at idle in just a few minutes. This thing is heavy duty and comes in a nice compact kit. It's made in Australia and cost about $200.00
