I've been searching, have some answers, some I am not too sure.
05 Quad with stock base am/fm/cd
So in no order....
Need to tap into front speaker wires.....color codes please?
Depth for front speakers, max.
Can an 8" fit in front doors? Anyone done it?
Anyone done a woofer, mid combo in the front door? (meaning 2 speakers)
I will start here.
Thanks for your help
Don Vito
EDIT: Post 666 ;)
MEM RED +
PWR Red/White +
GND Black -
Dim Orange/White
Ant Yellow
RF Violet +
RF Vio/Yel -
LF Green +
LF Green/Yellow -
RR Blue/Red +
RR Blue/White -
LR Brown +
LR Brown/Yellow -
I think these are right, won't swear to it though. As far as mounting depth I am not sure, about the max depth but I know my alpine speakers have a 2
1/2 inch depth and fit with a good 3/4 of an inch to spare. I thought about trying to put some memphis sync 8's in the door, then I found out they don't make them anymore. Don't see why they wouldn't fit.
Thanks for that.
I will keep looking/asking around as I found the wire list with other colors.
As for the 8" speakers, I guess I will just have to get a pair and see.
8"s will fit, I had a set of kicker MB8s for a few months and just took a bit of trimming and an inch and a half spacer (took out the factory 2" spacer) pretty easy install. With the factory plastic spacer out of the truck you have damn near no room but you can easily build up about a 2 3/4 inch spacer and still fit behind the factory door panel.
As far as the radio colors I can double check my truck for ya in a bit but there is no switched power behind the radio you have to pull that from either ignition harness or the easy way is to just pull it off the cig. lighter switched power.
If you need any help feel free to PM me any questions.
