  1. I have 2000 caravan se v6 3.8l when van is off i can pump brake pedal few times its hard then gets a little soft. When van is running pedal goes to floor. I pump it and seems to get hard a little bit but doesnt stay hard. Im beliveing the abs module and pump is bad. Checked fuses and connetors all good even gravity bleed brakes. Still nothing. Is it possible the master cylinder bad ? I see no leakage. And no abs light on. Engine light on but no codes come up its blank like there is no problem. I have power to plug on module really like to know more info abs module is $485 new dont have that
