1 - 2 of 2 Posts
Thank you...drive thru
I went to switch out my old antenna for a new shorty and broke the copper clip. When it broke, it went flying and now I don't know how to put in the replacement (which wasn't cheap). Where can I find some how-to help on install? Right now the antenna is real loose and falls into the fender well if I unscrew the antenna.
Retired Guy
I know if you pull the trim right by the front door on the pass. side, you can see the inside of the fender and the connection for the ant.
HTH
1 - 2 of 2 Posts
