1 - 6 of 6 Posts
Would it cause any problems to connect a hose to the crank case breather tube and re route it back behind the cab? The smell from rotella gets in my heat vents and in the cab that is why I need to re route if possible.
Diesel User
You can. But one word of warning. If it freezes in your area I wouldn't do it. Moisture condenses in that extra long tube and could plug the breather when it freezes.
MikeyB
Or you could switch motor oils. I hear that Valvoline stuff is supposed to be pretty good and doesn't have the "refreshing" scent. :D
yeah i'm using the valvoline tection 15w-40.. seems okay but i'm no expert
I've changed the oil twice and the smell is still there. Must be residue.
1 - 6 of 6 Posts
