21 - 40 of 40 Posts
Bridal Veil Falls
Discussion Starter #21
I did clean those areas, it was ugly
Wow bro! Your calipers took a beating. i would have those replaced also if i was you!
i need to do the breaks on my 2nd gen soon.
Bridal Veil Falls
Discussion Starter #23
The Calipers are fine, I cleaned them up too....
The rotors are nice, only 128.00 bucks for the set off of ebay, with free shipping...
Bridal Veil Falls
Discussion Starter #25
It is much better.
I need to pull my back wheels off and bleed the rear brakes, I wasn't able to do that when I blew out the rear brake line behind the gas tank last year...
I was wondering if I could pull the rear disk brakes off of an '02 or newer ram and put them on mine anyone know if this is possible?
you have 3 rubber brake hoses, 1 at the differential, one on each front wheel... while you are doing brake work id make sure those arent bulgy or cracked ... if so go stainless for about $60
Beware the Underbite!!!
your rears may also need an adjustment if you had them off. my auto adjusters stopped working correctly, so i had to feed them out, and it gave it enough for them to start working right
Bridal Veil Falls
Discussion Starter #28
I didn't mess with the rears, but I need to...
ok. well hurry up and get it fixed.
Bridal Veil Falls
Discussion Starter #30
Get what fixed?
I fixed my front brakes, I want to know if I can replace the rear drums system with a disk system off of a new model ram?
the soft pedal feel
Bridal Veil Falls
Discussion Starter #32
Oh, that is going to require me to remove the back wheels and bleed the brakes, I rounded off the vent valve last time I tried....
shouldnt require that.
Bridal Veil Falls
Discussion Starter #34
It will for me, I am short and round so getting up in there to remove the vent valve and replace it will require some room....
mine locked up when they were out of adjustment (my shoes were too far in) when i wound them out to where they were just about to touch the drum the auto adjusters wound out and put them in the proper place
Bridal Veil Falls
Discussion Starter #38
Update on the brakes...
I got help today from our truck, tractor trailer, mechanics to bleed all four corners of the brakes, helps when you have a creeper and a shop full of tools....
Wow what a difference, I don't have to hardly push on the pedal to get some serious stopping power....
Will actually lock em up now...
21 - 40 of 40 Posts
