2006 Grand Caravan base model. The piston in the left, rear brake caliper cracked in half releasing the pressure in the brake system. I believe this activated the split-diagonal brake proportioning valve which seems to have shut off brake fluid going to the left, rear and right, front calipers because when I try to bleed the system after replacing both rear calipers, there is no fluid going to the left, rear or right, front brakes, there is not much pressure building up in the system and there is no fluid leaking out anywhere. Does anyone know where the brake proportioning valves / metering valves / pressure switches on this model are and is there anything else I should check to see what's going on?
