My brake light is on I set my emergency brake and once released the light never went off. Any suggestions on how to fix?
Thanks
Paul
Did ya check the switch at the footbrake? If you've never used your brake and then one day decided to use it, the switch could have gotten stuck. You could use dielectric grease to lube it up
This is exactly what happened, I very rarely use the brake. Is the switch on the pedal mechanism if not were is it located.
Thanks
Paul
Yep, its right where the footbrake pivots, easy to see.
