1 - 2 of 2 Posts
I had just purchased 05' Quad cab 2500 4x4 w/toe package. I would like to install a brake controller. On my old Ford I had to have a circuit breaker in line on the feed. This Truck came with a pig tail that plugs under the dash for a controller. Is it still neccesary for the breaker or does the truck have one built in. Is it Just plug in play.
If you have the factory trailer hitch then there is a blue plug up near the steering column underneath the dash. You should have gotten the other part of that harness with the truck that you wire to the controller. If you didn't get the second part of the harness you can get it at the dealer. Its plug and play from there.
1 - 2 of 2 Posts
