Hello All,
I have a 2001 Dodge Ram Van 3500 5.2L.
I purchased the van in Nov. 2019 and the man I bought it from said the heat/air blower switch needs replaced, it only works in high. it quit blowing on high and would work on/off, when it wanted too. I thought no big deal....HA on me! I went to the auto parts store, the manager said try the resistor? (Hope I called that right) first, under the hood on the firewall next the the a/c cover box, if you do it in parking lot I'll let you return it. Well, it wasn't that and so I went and traded that $30 part for a switch which costs about the same, tried it and it wasn't that either so I got my money back and went on my way. I got one of those dash defrosters and used it the rest of that winter, weather was mild, it was fine. Then this winter hit and it has not been mild so I finally ordered a blower motor and then I got my bf to put it on the van and it blows again BUT only on high. When I bought the van it had some issues like I had to have a new fuel pump, and then I had to start replacing parts till I found the solution to the big issue which was; the van was dying going down road, sometimes would restart, sometimes you had to let it sit for a bit, sometimes ether would work, sometimes not and it got harder to get started the longer time went. So I posted on here to get advice and found it's an issue that's kind of hard to pin down so I replaced all 6 relays, went through the fuses and made sure they were all good and the right size etc... I replaced rotor button, distributor cap, distributor pick up coil, air filter, crankcase breather element (it was clogged), gas cap (had a code), and I solved the issue of it dying by replacing the crankshaft position sensor. Then a heater valve broke and had to be replaced, the headlamp switch had a blade that was burnt and the headlights would sometimes blink off when you hit a bump, I fixed that and finally the blower motor was replaced. I also just got 2 new front tires and hopefully next month will get 2 new back tires. So now you have the history of what I've done so here goes the brain picking....lol
1a. The blower motor only blows on high...resistor, switch or something else?
1b. The air coming out of the heater is lukewarm, why? Can it be fixed?
1c. It doesn't blow very well out of the vents or the floor. Why? How do I fix?
2. Also my gas mileage was really awesome for a vehicle this size, about 17 mph local. I've changed the oil twice since getting the van, we go fishing every day and put a lot of miles on the old girl...and the 2 tires so far and though it does seem better, i haven't fully recovered the great mileage I was getting....what all can mess with my mpg?
3. The gear selector is messed up. Was when I got it. It shows park and reverse then you have to pay attention or count to make sure your in drive. Is this just the cable needing adjusting? If so, can you tell me exactly where the adjuster is located? We've looked under dash under wheel but can't see it. I haven't changed transmission fluid and screen yet and I do know that's when your supposed to adjust/tighten the bands so could it be that? Suggestions?
4. It has the regular old headlamps and I would love to get those nice bright LEDs, do I have to change the whole lamp or do they make replacement bulbs that will fit?
5. The door trims need replaced, water actually runs off the roof and down the doors and through the gap in the middle. I've looked at replacement trim and it's very confusing to me. What do I get?
6. One of the side and one of the back doors have to be slammed or they won't shut all the way. They swing easily though so can I adjust them? How?
I'll stop there for now and once I these issues taken care of, I'll come back and pick your brains some more...lol
Thanks in advance for all your help, thoughts and ideas....they are greatly appreciated!!!!!
