Well, I installed the HTB2 turbo today and as per the advise of another member I just ran a jumper between the two wires for the plug going to the wastegate. Got it installed and it fired right up. While I was all dirty I decided to install my Genos fuel cap so I could hook up my FP guage. I thought I could reuse the rubber O-ring but fuel went everywhere and I realized that the O-ring had squeezed out and needed to be replaced. Got one and installed it and truck started fine but ran a little rough as they sometimes due after a fuel filter change. The idle smoothed out and I took it for a spin and after about 100yds the engine got real loud and "Dieseled" for a split second. I thought maybe I had pushed on the accelerator on accident and continued with my ride. It did it a couple more times during my ride. I got back home and checked for codes and man they just kept coming!!!
P0336 Crankshaft Position Sensor Performance
P0341 Camshaft Position Sensor Performance / Rationality
These two are probably from me hooking up the TST plugs backwards last week but kind of strange that they just showed up.
P0148 Fuel Delivery Error
Possibly from the fuel running out of the canister due to the O-ring pushing out. The truck did run kind of rough when I first started it up but I figured it was because the fuel filter had been in and out and that I probably had an air bubble in the system somewhere. The idle did smooth out before I left for my ride but it did take a couple minutes.
P0073 Ambient Temp Sensor Too High
This one is probably from me starting the engine without the air temp sensor plugged in!!
P0107 Manifold Absolute Pressure Sensor Low
P0243 ????
It's the last two that I am not sure of. Anybody know what these mean?? I'm afraid to drive the truck now because it feels like it's gonna die when it starts acting strangely.
Should I have jumpered the two wires in the wastegate plug? Or should I have just plugged it to keep moisture out??
I unhooked the batteries for a little while and then reconnected them. The codes are all gone but the truck was still running rough last time it would start.
I'm pretty sure the turbo has nothing to do with the truck running badly. I think I got air in the fuel system but I don't know how to get rid of it!! I pulled the TST/MP8 off in case she has to go to the dealership and now the truck won't start at all!! It won't even crank! I messed with it for a while but found nothing. While I was sleeping I started thinking about those wire taps that come with the TST. They spread the contacts for the fuses out and when you remove them the contacts stay spread apart!! So, I think that when I put my fuses back in that the one side is not even touching the contacts! I hope that's all the no start issue is!! I've got enough problems already!!!
I think she's gonna end up on the back of a rollback.......
P0243 ????
