I have a 2004 dodge neon awhile ago my brake lights went out but would work if I had my lights on. A little bit after my turning signals stopped working. I took it to the shop and they said I had a bad combination switch and there was a burnt wire inside. Now the brake lights do not work at all. I switched the Brake light switch and only the third brake light is working and it wont turn off. I also switched my signal flasher, any reason my turning signals, hazards and bottom brake lights wont turn on?
