I just got my Auto Meter boost gauge and installed the T fitting in the vacuum line like the directions said, but obviously it's acting as a vacuum gauge, not a boost gauge. They didn't give me near enough hose to run to my waste gate line, but I assume that's where I need to install the T. Any help along with a pic or two would sure be helpful. Also, should I run the gauge light off the headlight switch? If so, which fuse is that? Also, one more thing, my tranny temp sensor... where do I install it? The directions say that I may need to drill a hole in the pan and weld or braze a bushing to it. I'm hoping that's BS and I can install it somewhere else. Thanks for the help guys.
