1 - 3 of 3 Posts
I HAV A 1999 RAM 1500 2WD AUTO 5.9L. MY ODOMETER WAS BLINKIN AFTER DISCONNECTIN TH NEGATIVE BATTERY CABLE 4 AWHILE THEN RECONNECTIN IT. WEN I WENT 2 RECONNECT IT, IT SPARKED/ARCED REALLY BIG. WEN I WENT 2 START TH TRUK AGAIN, IT CRANKED A HALF TURN & QUIT. LIKE TH BATTERY JST WENT DEAD. THE ODODMETER STARTED BLINKIN WEN I TURNED TH IGNITION ON..I RESEARCHED IT & FOUND OUT THT TH PCM WENT BAD WEN IT ARCED.
I PUT ON A NEW PCM (SUM1 TOLD ME IN ANOTHER FORUM THT I NEEDED 2 TURN TH IGNITION ON & WAIT 15 SECS B4 STARTING IT 4 TH 1ST TIME AFTER PUTTIN TH NEW PCM IN). ONLY, I 4GOT THT PART. I FIRED IT RITE UP.
TH ODOMETER STILL BLINKS & NOW TH NEEDLES JUMP IN TIME WITH TH ODOMETER ON ALL TH GAUGES. HELP!!! :crying
Did you ever get this fixed? I had the water pump replaced and now have a blinking odometer and a tick tok sound like the turn signal is on. When I shut the door it goes back to normal in about 30 seconds after starting. Stays ok till I open the door or turn off the ignition. This may not bee what you had but I was wondering what you finally did.
hi out there in fiat land...this is my first post (have been visiting for quite a while) so here goes my odometer has begun squinting, this is the first run through its done this. any recommendations? I watched the obscuration today...just thinking about whether the 'we are being watched' may be true....192.168.100.1 192.168.1.1 jpg to pdf
1 - 3 of 3 Posts
