If you're talkin to me, yes I dont know what I'm talking about. I just like to get my post count up. I'm no gonna get into a pissing contest bc it gets covered every other week on here.
I also know that a 6" lift plus Bilsteins does not give you 9" of lift. Thats in my sig to make fun of Scott, sorry you didnt get the memo. Sorry you got butthurt when i called your lift pro crap. Maybe if you search this forum about the lifts for the 4th gens, you'll see I tweak all the lifts names. Also while searching maybe you'll learn something about these lifts, seems like you dont know too much either.
The lifts are all basically the same. Which is obvious bc it can only be lifted so many different ways. Like yours has a 4.5" strut spacer and mine having a 5.5" strut spacer. Neither are 9" or 8.8" with bilstiens. Mine is 8.3" and yours is 7.3". Your rear lift is 5.5" depending on how many of those spacers you got, every pro comp owner seems to have different ones. No one has 6" of rear lift, Well i do bc I have lifted springs at 4.5" and a 1.5" spacer on top of that. You should also note that your Pro Comp is the only lift not to come with a skid plate. Which is weird, having less ground clearance than other lifts I would definately think they would have one.
Are you saying we should go by our rear lift height? Obviously no one has 9" lift all the way around, that would look retarded. So the PC lift is 5.5" and BDS 5" or 3" depending on which option you got and lastly the rough and crappy lift being 4.5". Not real sure where you were going with that, well or your whole post for that matter. You should definately learn about the lifts bc you seem to know nothing. Matter of fact, you should call EVERY lift company and right down the specs of the lift as well has how the lift is acheived and how much because thats what i did. After that we can compare notes and maybe you wont come off sounding so dumb. Until then, have a good Holiday
